Analysis of an Age-structured SIL model with demographics process and vertical transmission - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue Africaine de Recherche en Informatique et Mathématiques Appliquées Année : 2014
We consider a mathematical SIL model for the spread of a directly transmitted infectious disease in an age-structured population; taking into account the demographic process and the vertical transmission of the disease. First we establish the mathematical well-posedness of the time evolution problem by using the semigroup approach. Next we prove that the basic reproduction ratio R0 is given as the spectral radius of a positive operator, and an endemic state exist if and only if the basic reproduction ratio R0 is greater than unity, while the disease-free equilibrium is locally asymptotically stable if R0<1. We also show that the endemic steady states are forwardly bifurcated from the disease-free steady state when R0 cross the unity. Finally we examine the conditions for the local stability of the endemic steady states.
Vol.17.pp.23-52.pdf (3.63 Mo) Télécharger le fichier
hal-01300058 , version 1 (08-04-2016)
Ramses Djidjou Demasse, Jean Jules Tewa, Samuel Bowong. Analysis of an Age-structured SIL model with demographics process and vertical transmission. Revue Africaine de Recherche en Informatique et Mathématiques Appliquées, 2014, Volume 17 - 2014 - Special issue CARI'12, pp.23-52. ⟨10.46298/arima.1966⟩. ⟨hal-01300058⟩
Collections
AFRIQ INRIA LIRIMA
183 Consultations
1052 Téléchargements
