LDPE Surface Modifications Induced by Atmospheric Plasma Torches with Linear and Showerhead Configurations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Plasma Processes and Polymers Année : 2015
Low density polyethylene (LDPE) surfaces have been plasma modified to improve their nanostructural and wettability properties. These modifications can significantly improve the deposition of subsequent layers such as films with specific barrier properties. For this purpose, we compare the treatments induced by two atmospheric plasma torches with different configurations (showerhead vs. linear). The modifications of LDPE films in terms of chemical surface composition and surface morphology are evidenced by X-ray photoelectron spectro-scopy, water contact angles measurements, and atomic force microscopy. A comparison between the two post-discharge treatments is achieved for several torch-to-substrate distances (gaps), treatment times, and oxygen flow rates in terms of etching rate, roughening rate, diffusion of oxygen into the subsur-face and hydrophilicity. By correlating these results with the chemical composition of the post-discharges, we identify and compare the 'species which are responsible for the chemical surface functionalization, the surface roughening, and etching.
Pre-Print-022.pdf (1.59 Mo) Télécharger le fichier
hal-01303182 , version 1 (29-04-2016)
hal-01303182 , version 2 (04-04-2023)
Sami Abou Rich, Thierry Dufour, Perrine Leroy, François Reniers, Laurent Nittler, et al.. LDPE Surface Modifications Induced by Atmospheric Plasma Torches with Linear and Showerhead Configurations. Plasma Processes and Polymers, 2015, 12 (8), pp.771-785. ⟨10.1002/ppap.201400097⟩. ⟨hal-01303182v1⟩
37 Consultations
87 Téléchargements
