Some approximate methods for computing electromagnetic fields scattered by complex objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Measurement Science and Technology Année : 1998
We discuss several approximate methods for computing electromagnetic scattering by objects of complex shape. Depending on the relative size of the scatterer compared to the incident wavelength, different techniques have to be designed. We review some of them which are often used in practice, and present numerical results of scattering by complex objects.
CT.pdf (567.09 Ko) Télécharger le fichier
hal-01304870 , version 1 (23-03-2018)
Pierre Chiappetta, Bruno Torrésani. Some approximate methods for computing electromagnetic fields scattered by complex objects. Measurement Science and Technology, 1998, 9 (2), pp.171-182. ⟨10.1088/0957-0233/9/2/005⟩. ⟨hal-01304870⟩
255 Consultations
359 Téléchargements
