The decidable properties of subrecursive functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
What can be decided or semidecided about a primitive recursive function, given a definition of that function by primitive recursion? What about subrecursive classes other than primitive recursive functions? We provide a complete and explicit characterization of the decidable and semidecidable properties. This characterization uses a variant of Kolmogorov complexity where only programs in a subrecursive programming language are allowed. More precisely, we prove that all the decidable and semidecidable properties can be obtained as combinations of two classes of basic decidable properties: (i) the function takes some particular values on a finite set of inputs, and (ii) every finite part of the function can be compressed to some extent.
ricelike.pdf (433.38 Ko) Télécharger le fichier
hal-01308224 , version 1 (27-04-2016)
Paternité
Mathieu Hoyrup. The decidable properties of subrecursive functions. International Colloquium on Automata, Languages, and Programming (ICALP) 2016, Jul 2016, Rome, Italy. ⟨10.4230/LIPIcs.ICALP.2016.108⟩. ⟨hal-01308224⟩
449 Consultations
1063 Téléchargements
