Doubly-resonant saddle-nodes in $(\mathbb{C}^{3},0)$ and the fixed singularity at infinity in the Painlevé equations (part II): sectorial normalization. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
In this work, following [Bit15], we consider analytic singular vector fields in $(\mathbb{C}^{3},0)$ with an isolated and doubly-resonant singularity of saddle-node type at the origin. Such vector fields come from irregular two-dimensional differential systems with two opposite non-zero eigenvalues, and appear for instance when studying the irregular singularity at infinity in Painlevé equations (P_j), j=I...V , for generic values of the parameters. Under suitable assumptions, we prove a theorem of analytic nor-malization over sectorial domains, analogous to the classical one due to Hukuhara-Kimura-Matuda [HKM61] for saddle-nodes in $(\mathbb{C}^{2},0)$. We also prove that the normalizing map is essentially unique and weakly Gevrey-1 summable.
analytic normalization.pdf (684.08 Ko) Télécharger le fichier
hal-01314950 , version 1 (13-05-2016)
hal-01314950 , version 2 (18-05-2016)
hal-01314950 , version 3 (31-05-2016)
hal-01314950 , version 4 (24-06-2016)
hal-01314950 , version 5 (17-11-2016)
Amaury Bittmann. Doubly-resonant saddle-nodes in $(\mathbb{C}^{3},0)$ and the fixed singularity at infinity in the Painlevé equations (part II): sectorial normalization.. 2016. ⟨hal-01314950v2⟩
280 Consultations
72 Téléchargements
