Atomic Object Factory: Efficient, Consistent and Dependable Support for Distributed Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
This paper introduces Atomic Object Factory (AOF), a novel implementation of the distributed object paradigm. AOF allows client applications to transparently manipulate and share remotely-stored objects, while providing strong guarantees on dependability, consistency and persistence. It leverages the support of a listenable key-value store (LKVS), a novel NoSQL storage abstraction that we introduce in this paper. AOF offers integrated language support at the application-facing interface tier. Its middle tier implements the distributed object functionalities atop the LKVS, including coordinated replication. AOF does not rely on a mapping phase and deals with objects end-to-end. It allows the composition of these objects and provide efficient access to their methods. In particular, AOF guarantees disjoint access parallelism: operations on distinct distribued objects make use of distinct LKVS components and execute in parallel. We assess the benefits of our approach in practice by comparing the implementation of a personal cloud storage service using AOF, to an implementation of the same application with a state-of-the-art object-relational mapping over a sharded PostgreSQL database. Our results show that AOF offers a simpler programming framework both in terms of learning time and lines of code, while performing better on average and being more scalable.
paper.pdf (1.2 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01318706 , version 1 (19-05-2016)
  • HAL Id : hal-01318706 , version 1
Pierre Sutra, Etienne Rivière, Cristian Cotes, Marc Sánchez Artigas, Pedro Garcia Lopez, et al.. Atomic Object Factory: Efficient, Consistent and Dependable Support for Distributed Objects. [Research Report] Télécom SudParis; Université de Neuchâtel; Universitat Rovira i Virgili; Red Hat. 2016. ⟨hal-01318706⟩
196 Consultations
140 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
