Estimation of the bias parameter of the Skew Random Walk and application to the Skew Brownian motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We study the asymptotic property of simple estimator of the parameter of a Skew Brownian Motion when one observes its positions on a fixed grid --- or equivalently of a simple random walk with a bias at zero. This estimator, nothing more than the Maximum Likelihood Estimator, is based only on the number of passages of the random walk at zero. It is very simple to set up, is consistent and satisfies the local asymptotic mixed normality. We believe that this simplified framework is helpful to understand the asymptotic behavior of the maximum likelihood of the Skew Brownian Motion observed at discrete times which is studied in a companion paper.
srw_estimation_R2.pdf (502.91 Ko) Télécharger le fichier
hal-01319319 , version 1 (20-05-2016)
hal-01319319 , version 2 (07-01-2017)
hal-01319319 , version 3 (17-04-2017)
hal-01319319 , version 4 (12-05-2017)
  • HAL Id : hal-01319319 , version 3
Antoine Lejay. Estimation of the bias parameter of the Skew Random Walk and application to the Skew Brownian motion. 2017. ⟨hal-01319319v3⟩
788 Consultations
487 Téléchargements
