Excitons in boron nitride single layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review B: Condensed Matter and Materials Physics (1998-2015) Année : 2016
Boron nitride single layer belongs to the family of 2D materials whose optical properties are currently receiving considerable attention. Strong excitonic effects have already been observed in the bulk and still stronger effects are predicted for single layers. We present here a detailed study of these properties by combining $ab\ initio$ calculations and a tight-binding-Wannier analysis in both real and reciprocal space. Due to the simplicity of the band structure with single valence ($\pi$) and conduction ($\pi^*$) bands the tight-binding analysis becomes quasi quantitative with only two adjustable parameters and provides tools for a detailed analysis of the exciton properties. Strong deviations from the usual hydrogenic model are evidenced. The ground state exciton is not a genuine Frenkel exciton, but a very localized ``tightly-bound'' one. The other ones are similar to those found in transition metal dichalcogenides and, although more localized, can be described within a Wannier-Mott scheme.
halhBN_SL.pdf (2.27 Mo) Télécharger le fichier
hal-01323899 , version 1 (31-05-2016)
Thomas Galvani, Fulvio Paleari, Henrique P. C. Miranda, Alejandro Molina-Sanchez, Ludger Wirtz, et al.. Excitons in boron nitride single layer. Physical Review B: Condensed Matter and Materials Physics (1998-2015), 2016, 94, pp.125303. ⟨10.1103/PhysRevB.94.125303⟩. ⟨hal-01323899⟩
567 Consultations
659 Téléchargements
