Competition between Spin Echo and Spin Self-Rephasing in a Trapped Atom Interferometer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
We perform Ramsey interferometry on an ultracold 87Rb ensemble confined in an optical dipole trap. We use a $\pi$-pulse set at the middle of the interferometer to restore the coherence of the spin ensemble by canceling out phase inhomogeneities and creating a spin echo in the contrast. However, for high atomic densities, we observe the opposite behavior: the $\pi$-pulse accelerates the dephasing of the spin ensemble leading to a faster contrast decay of the interferometer. We understand this phenomenon as a competition between the spin-echo technique and an exchange-interaction driven spin self-rephasing mechanism based on the identical spin rotation effect (ISRE). Our experimental data is well reproduced by a numerical model.
SEvsSSR.pdf (529.89 Ko) Télécharger le fichier
hal-01324582 , version 1 (01-06-2016)
hal-01324582 , version 2 (21-10-2016)
Cyrille Solaro, Alexis Bonnin, Frédéric Combes, Matthias Lopez, Xavier Alauze, et al.. Competition between Spin Echo and Spin Self-Rephasing in a Trapped Atom Interferometer. 2016. ⟨hal-01324582v1⟩
406 Consultations
407 Téléchargements
