Preconditioning a coupled model for reactive transport in porous media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We study numerical methods for solving reactive transport problems in porous media that allow a separation of transport and chemistry at the software level, while keeping a tight numerical coupling between both subsystems. After recalling how each individual subsystem can be solved, we give a formulation that eliminates the local chemical concentrations, and keeps the total concentrations as unknowns. The block structure of the model is exploited both at the nonlinear level, by eliminating some unknowns, and at the linear level by using block Gauss-Seidel or block Jacobi preconditioning. The methods are applied to the easy 1D case of the MoMaS benchmark.
CPU_time_adapt.pdf (10.79 Ko) Télécharger le fichier
ArticlePrecond-ETNA.pdf (1.03 Mo) Télécharger le fichier
hal-01327307 , version 1 (06-06-2016)
hal-01327307 , version 2 (09-09-2017)
hal-01327307 , version 3 (28-11-2017)
hal-01327307 , version 4 (09-10-2018)
Laila Amir, Michel Kern. Preconditioning a coupled model for reactive transport in porous media. 2017. ⟨hal-01327307v3⟩
723 Consultations
254 Téléchargements
