On the analysis of perfectly matched layers for a class of dispersive media and application to negative index metamaterials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
This work deals with Perfectly Matched Layers (PMLs) in the context of dispersive media, and in particular for Negative Index Metamaterials (NIMs). We first present some properties of dispersive isotropic Maxwell equations that include NIMs. We then demonstrate numerically the inherent instabilities of the classical PMLs applied to NIMs. We propose and analyse the stability of very general PMLs for a large class of dispersive systems using a new change of variable. We give necessary criteria for the stability of such models. For dispersive isotropic Maxwell equations, this analysis is completed by giving necessary and sufficient conditions of stability. Finally, we propose new PMLs that satisfy these criteria and demonstrate numerically their efficiency.
article.pdf (2.84 Mo) Télécharger le fichier
hal-01327315 , version 1 (06-06-2016)
hal-01327315 , version 2 (14-02-2017)
hal-01327315 , version 3 (12-07-2017)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-01327315 , version 2
Eliane Bécache, Patrick Joly, Valentin Vinoles. On the analysis of perfectly matched layers for a class of dispersive media and application to negative index metamaterials. 2016. ⟨hal-01327315v2⟩
1310 Consultations
606 Téléchargements
