Scaling-up Empirical Risk Minimization: Optimization of Incomplete U-statistics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2016
In a wide range of statistical learning problems such as ranking, clustering or metric learning among others, the risk is accurately estimated by U-statistics of degree d ≥ 1, i.e. functionals of the training data with low variance that take the form of averages over k-tuples. From a computational perspective, the calculation of such statistics is highly expensive even for a moderate sample size n, as it requires averaging O(n^d) terms. This makes learning procedures relying on the optimization of such data functionals hardly feasible in practice. It is the major goal of this paper to show that, strikingly, such empirical risks can be replaced by drastically computationally simpler Monte-Carlo estimates based on O(n) terms only, usually referred to as incomplete U-statistics, without damaging the O(1/√n) learning rate of Empirical Risk Minimization (ERM) procedures. For this purpose, we establish uniform deviation results describing the error made when approximating a U-process by its incomplete version under appropriate complexity assumptions. Extensions to model selection, fast rate situations and various sampling techniques are also considered , as well as an application to stochastic gradient descent for ERM. Finally, numerical examples are displayed in order to provide strong empirical evidence that the approach we promote largely surpasses more naive subsampling techniques.
jmlr16.pdf (682.24 Ko) Télécharger le fichier
hal-01327662 , version 1 (06-06-2016)
Stéphan Clémençon, Igor Colin, Aurélien Bellet. Scaling-up Empirical Risk Minimization: Optimization of Incomplete U-statistics. Journal of Machine Learning Research, 2016, 17 (76), pp.1-36. ⟨hal-01327662⟩
Relations
245 Consultations
124 Téléchargements
