Provenance in Systems for Situation Awareness in Environmental Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Markus Stocker
  • Fonction : Auteur
  • PersonId : 983233
Mauno Rönkkö
  • Fonction : Auteur
  • PersonId : 983234
Mikko Kolehmainen
  • Fonction : Auteur
  • PersonId : 983235
As environmental monitoring systems increasingly automate the collection and processing of environmental sensor network data, the technical components of such systems can automatically obtain and maintain higher levels of situation awareness—awareness of the monitored part of reality. In order to increase confidence in the correctness of situation awareness maintained by such systems it is important to explicitly model provenance. We present an alignment of the PROV ontology with ontologies used in a software framework for situation awareness in environmental monitoring, called Wavellite. The extended vocabulary enables the explicit representation of provenance in Wavellite applications. We demonstrate the implementation for a concrete scenario.
978-3-319-15994-2_16_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01328546 , version 1 (08-06-2016)
Paternité
Markus Stocker, Mauno Rönkkö, Mikko Kolehmainen. Provenance in Systems for Situation Awareness in Environmental Monitoring. 11th International Symposium on Environmental Software Systems (ISESS), Mar 2015, Melbourne, Australia. pp.169-177, ⟨10.1007/978-3-319-15994-2_16⟩. ⟨hal-01328546⟩
28 Consultations
59 Téléchargements
