Water Pollution Reduction: Reverse Combinatorial Auctions Modelling Supporting Decision-Making Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Petr Šauer
  • Fonction : Auteur
  • PersonId : 983245
Petr Fiala
  • Fonction : Auteur
  • PersonId : 983246
Antonín Dvořák
  • Fonction : Auteur
  • PersonId : 983247
This paper presents a model that contributes to finding cost-effective solutions when making decisions about building wastewater treatment plants in the planning process defined in the Framework Directive 2000/60/EC of the European Parliament and of the European Council. The model is useful especially when construction and operation of joint wastewater treatment plants is possible for several (neighbouring) municipalities, where a huge number of theoretical coalitions is possible. The paper presents the model principles for one pollutant and for multiple pollutants, describes the CRAB software used for computing the optimal solutions and presents selected applications. It concludes that the computations can contribute directly to decision-making concerning environmental protection projects and also serve for calculating background models for economic laboratory experiments in the area.
978-3-319-15994-2_19_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01328549 , version 1 (08-06-2016)
Paternité
Petr Šauer, Petr Fiala, Antonín Dvořák. Water Pollution Reduction: Reverse Combinatorial Auctions Modelling Supporting Decision-Making Processes. 11th International Symposium on Environmental Software Systems (ISESS), Mar 2015, Melbourne, Australia. pp.196-206, ⟨10.1007/978-3-319-15994-2_19⟩. ⟨hal-01328549⟩
31 Consultations
80 Téléchargements
