Measuring and Benchmarking Corporate Environmental Performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alena Kocmanová
  • Fonction : Auteur
  • PersonId : 983319
Jana Hornungová
  • Fonction : Auteur
  • PersonId : 983320
Corporate environmental performance is discussed in this paper. The aim of the paper is to propose a framework for an environmental performance benchmarking model. Corporate environmental performance is measured by key performance indicators (KPIs): Emissions of Greenhouse Gases, Water Consumption, Waste Production and Gross Value Added. Performance is benchmarked against the production frontier estimated by Data Envelopment Analysis. The environmental performance benchmarking model was created and tested on real corporate data. The model determines relative corporate environmental performance, identifies weaknesses in performance and quantifies performance gaps.
978-3-319-15994-2_51_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01328598 , version 1 (08-06-2016)
Paternité
Marie Pavláková Dočekalová, Alena Kocmanová, Jana Hornungová. Measuring and Benchmarking Corporate Environmental Performance. 11th International Symposium on Environmental Software Systems (ISESS), Mar 2015, Melbourne, Australia. pp.503-511, ⟨10.1007/978-3-319-15994-2_51⟩. ⟨hal-01328598⟩
76 Consultations
442 Téléchargements
