The best of both worlds: synthesis-based acceleration for physics-driven cosparse regularization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recently, a regularization framework for ill-posed inverse problems governed by linear partial differential equations has been proposed. Despite nominal equivalence between sparse synthesis and sparse analysis regularization in this context , it was argued that the latter is preferable from computational point of view (especially for huge scale optimization problems arising in physics-driven settings). However, the synthesis-based optimization benefits from simple, but effective all-zero initialization, which is not straightforwardly applicable in the analysis case. In this work we propose a multiscale strategy that aims at exploiting computational advantages of both regularization approaches.
152120_itwist16_paper.pdf (249.77 Ko) Télécharger le fichier
hal-01329051 , version 1 (08-06-2016)
  • HAL Id : hal-01329051 , version 1
Srdan Kitic, Nancy Bertin, Rémi Gribonval. The best of both worlds: synthesis-based acceleration for physics-driven cosparse regularization. iTwist 2016 - International Traveling Workshop on Interactions Between Sparse Models and Technology, Aug 2016, Aalborg, Denmark. ⟨hal-01329051⟩
391 Consultations
190 Téléchargements
