Cloud2IR: Infrared thermography and environmental sensors integrated in an autonomoussystem for long term monitoring of structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Since late 2014, the project Cloud2SM aims to develop a robust information system able to assess the long term monitoring of civil engineering structures as well as interfacing various sensors and data. Cloud2SM address three main goals, the management of distributed data and sensors network, the asynchronous processing of the data through network and the local management of the sensors themselves [1]. Integrated to this project Cloud2IR is an autonomous sensor system dedicated to the long term monitoring of infrastructures. Past experimentations have shown the need as well as usefulness of such system [2]. Before Cloud2IR an initially laboratory oriented system was used, which implied heavy operating system to be used [3]. Based on such system Cloud2IR has benefited of the experimental knowledge acquired to redefine a lighter architecture based on generics standards, more appropriated to autonomous operations on field and which can be later included in a wide distributed architecture such as Cloud2SM. The sensor system can be divided in two parts. The sensor side, this part is mainly composed by the various sensors drivers themselves as the infrared camera, the weather station or the pyranometers and their different fixed configurations. In our case, as infrared camera are slightly different than other kind of sensors, the system implement in addition an RTSP server which can be used to set up the FOV as well as other measurement parameter considerations.
EGU2016-12978.pdf (35.72 Ko) Télécharger le fichier
hal-01332799 , version 1 (17-06-2016)
Antoine Crinière, Jean Dumoulin, Laurent Mevel, Guillermo Andrade Barroso. Cloud2IR: Infrared thermography and environmental sensors integrated in an autonomoussystem for long term monitoring of structures. European Geoscience Union EGU2016, Apr 2016, Vienna, Austria. ⟨10.1088/1742-2132/10/6/064003⟩. ⟨hal-01332799⟩
193 Consultations
100 Téléchargements
