RAPP: A Robotic-Oriented Ecosystem for Delivering Smart User Empowering Applications for Older People - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Social Robotics Année : 2016
It is a general truth that increase of age is associated with a level of mental and physical decline but unfortunately the former are often accompanied by social exclusion leading to marginalization and eventually further acceleration of the aging process. A new approach in alleviating the social exclusion of older people involves the use of assistive robots. As robots rapidly invade everyday life, the need of new software paradigms in order to address the user's unique needs becomes critical. In this paper we present a novel architectural design, the RAPP [a software platform to deliver smart, user empowering robotic applications (RApps)] framework that attempts to address this issue. The proposed framework has been designed in a cloud-based approach, integrating robotic devices and their respective applications. We aim to facilitate seamless development of RApps compatible with a wide range of supported robots and available to the public through a unified online store.
article_rapp_ijsr_2016.pdf (942.71 Ko) Télécharger le fichier
hal-01336250 , version 1 (22-06-2016)
Sofia E Reppou, Emmanouil G. Tsardoulias, Athanassios M Kintsakis, Andreas L Symeonidis, Pericles A Mitkas, et al.. RAPP: A Robotic-Oriented Ecosystem for Delivering Smart User Empowering Applications for Older People. International Journal of Social Robotics, 2016, ⟨10.1007/s12369-016-0361-z⟩. ⟨hal-01336250⟩
361 Consultations
486 Téléchargements
