Computing hypergeometric functions rigorously - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
We present an efficient implementation of hypergeometric functions in arbitrary-precision interval arithmetic. The functions 0F1, 1F1, 2F1 and 2F0 (or the Kummer U-function) are supported for unrestricted complex parameters and argument, and by extension, we cover exponential and trigonometric integrals, error functions, Fresnel integrals, incomplete gamma and beta functions, Bessel functions, Airy functions, Legendre functions, Jacobi polynomials, complete elliptic integrals, and other special functions. The output can be used directly for interval computations or to generate provably correct floating-point approximations in any format. Performance is competitive with earlier arbitrary-precision software, and sometimes orders of magnitude faster. We also partially cover the generalized hypergeometric function pFq and computation of high-order parameter derivatives.
arb_plain.pdf (447.49 Ko) Télécharger le fichier
hal-01336266 , version 1 (22-06-2016)
hal-01336266 , version 2 (05-07-2016)
  • HAL Id : hal-01336266 , version 1
Fredrik Johansson. Computing hypergeometric functions rigorously. 2016. ⟨hal-01336266v1⟩
456 Consultations
6024 Téléchargements
