SPS co-sintered monolithic transformers for power electronics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2016
Power integration is a key issue to reduce the volume and weight of electronic devices in power applications. But, transformers produced using classical planar assembly are limited in design. Spark Plasma Sintering (SPS) is a relatively new technology to produce multimaterial compact system with higher density and using lower sintering temperature. The purpose of this study is to manufacture of a cubic-centimeter size transformers for high frequency application using SPS. The prototype presented in this paper is composed of two spiral copper coils separated by an insulated layer and encapsulated in ferrite powder. The assembly is then co-sintered by SPS. The magnetic material used for the transformers is a nickel-zinc based ferrite, with copper substitution to allow sintering at low temperatures. The low conductivity of this mixed-ferrite ensures operation in the frequency range of 1 to 20 MHz of our final system. Computed tomography scanning has been used to optimize the design of the co-sintered structures. Effects of the composition of the ferrite and the sintering temperature on the transformation ratio are discussed. It is shown that a ferrite with very low conductivity is required to ensure galvanic insulation, as there is a direct contact between the copper spirals and the magnetic parts.
adrienmercier_IEEE_HAL.pdf (452.24 Ko) Télécharger le fichier
hal-01340090 , version 1 (04-07-2016)
Adrien Mercier, K. Zehani, G. Chaplier, A. Pasko, V. Loyau, et al.. SPS co-sintered monolithic transformers for power electronics. IEEE Transactions on Magnetics, 2016, 52 (5), pp. 8400404. ⟨10.1109/TMAG.2015.2504876⟩. ⟨hal-01340090⟩
337 Consultations
212 Téléchargements
