Sparse-BSOS: a bounded degree SOS hierarchy for large scale polynomial optimization with sparsity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We provide a sparse version of the bounded degree SOS hierarchy BSOS [7] for polynomial optimization problems. It permits to treat large scale problems which satisfy a structured sparsity pattern. When the sparsity pattern satisfies the running intersection property this Sparse-BSOS hierarchy of semidefinite programs (with semidefinite constraints of fixed size) converges to the global optimum of the original problem. Moreover, for the class of SOS-convex problems, finite convergence takes place at the first step of the hierarchy, just as in the dense version.
sbsos_100217.pdf (531.58 Ko) Télécharger le fichier
hal-01341931 , version 1 (05-07-2016)
hal-01341931 , version 2 (03-03-2017)
hal-01341931 , version 3 (26-05-2017)
Tillmann Weisser, Jean-Bernard Lasserre, Kim-Chuan Toh. Sparse-BSOS: a bounded degree SOS hierarchy for large scale polynomial optimization with sparsity. 2017. ⟨hal-01341931v2⟩
630 Consultations
439 Téléchargements
