An algebraic continuous time parameter estimation for a sum of sinusoidal waveform signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Adaptive Control and Signal Processing Année : 2016
In this paper, a novel algebraic method is proposed to estimate amplitudes, frequencies, and phases of a biased and noisy sum of complex exponential sinusoidal signals. The resulting parameter estimates are given by original closed formulas, constructed as integrals acting as time-varying filters of the noisy measured signal. The proposed algebraic method provides faster and more robust results, compared with usual procedures. Some computer simulations illustrate the efficiency of our method.
UPM_JACSP_2016_pour_hal.pdf (367.42 Ko) Télécharger le fichier
hal-01342210 , version 1 (25-08-2016)
Rosane Ushirobira, Wilfrid Perruquetti, Mamadou Mboup. An algebraic continuous time parameter estimation for a sum of sinusoidal waveform signals. International Journal of Adaptive Control and Signal Processing, 2016, 30 (12), pp.1689-1713. ⟨10.1002/acs.2688⟩. ⟨hal-01342210⟩
265 Consultations
270 Téléchargements
