Improving Newton's method performance by parametrization: the case of Richards equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2017
The nonlinear systems obtained by discretizing degenerate parabolic equations may be hard to solve, especially with Newton's method. In this paper, we apply to Richards equation a strategy that consists in defining a new primary unknown for the continuous equation in order to stabilize Newton's method by parametrizing the graph linking the pressure and the saturation. The resulting form of Richards equation is then discretized thanks to a monotone Finite Volume scheme. We prove the well-posedness of the numerical scheme. Then we show under appropriate non-degeneracy conditions on the parametrization that Newton’s method converges locally and quadratically. Finally, we provide numerical evidences of the efficiency of our approach.
BC16-Richards.pdf (1023.83 Ko) Télécharger le fichier
hal-01342386 , version 1 (05-07-2016)
Paternité - Pas d'utilisation commerciale - Pas de modification
Konstantin Brenner, Clément Cancès. Improving Newton's method performance by parametrization: the case of Richards equation. SIAM Journal on Numerical Analysis, 2017, 55 (4), pp.1760--1785. ⟨hal-01342386⟩
1071 Consultations
1017 Téléchargements
