Learner Differences in the Online Context: Introducing a New Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Arne Hendrik Schulz
  • Fonction : Auteur
  • PersonId : 985794
Debora Jeske
  • Fonction : Auteur
  • PersonId : 985795
The paper introduces an alternative method to analyze different learning styles among students. This method was developed as an alternative to more traditional methods such as hierarchical cluster analysis. The method was tested using a large data set (n = 868) which included participants completing a small e-module in addition to a small number of measures to assess learner characteristics. The resulting log files were analyzed using the new method. Results were similar to those observed using traditional methods. The method provides a new starting point for subsequent analysis and identification of learner differences using other information such as log files from e-learning and Massive Online Open Courses (MOOCs).
978-3-662-45770-2_26_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01342714 , version 1 (06-07-2016)
Paternité
Arne Hendrik Schulz, Debora Jeske. Learner Differences in the Online Context: Introducing a New Method. IFIP Conference on Information Technology in Educational Management (ITEM) and IFIP Conference on Key Competencies for Educating ICT Professionals (KCICTP), Jul 2014, Potsdam, Germany. pp.306-317, ⟨10.1007/978-3-662-45770-2_26⟩. ⟨hal-01342714⟩
71 Consultations
116 Téléchargements
