A French corpus for distant-microphone speech processing in real homes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a new corpus for distant-microphone speech processing in domestic environments. This corpus includes reverberated , noisy speech signals spoken by native French talkers in a lounge and recorded by an 8-microphone device at various angles and distances and in various noise conditions. Room impulse responses and noise-only signals recorded in various real rooms and homes and baseline speaker localization and enhancement software are also provided. This corpus stands apart from other corpora in the field by the number of rooms and homes considered and by the fact that it is publicly available at no cost. We describe the corpus specifications and annotations and the data recorded so far. We report baseline results.
bertin_IS16.pdf (650.82 Ko) Télécharger le fichier
hal-01343060 , version 1 (07-07-2016)
  • HAL Id : hal-01343060 , version 1
Nancy Bertin, Ewen Camberlein, Emmanuel Vincent, Romain Lebarbenchon, Stéphane Peillon, et al.. A French corpus for distant-microphone speech processing in real homes. Interspeech 2016, Sep 2016, San Francisco, United States. ⟨hal-01343060⟩
943 Consultations
1188 Téléchargements
