Context Classifier for Service Robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper a context classifier for service robots is presented. Independently of the application, service robots need to have the notion of their context in order to behave appropriately. A context classification architecture that can be integrated in service robots reliability calculation is proposed. Sensorial information is used as input. This information is then fused (using Fuzzy Sets) in order to create a knowledge base that is used as an input to the classifier. The classification technique used is Bayes Networks, as the object of classification is partially observable, stochastic and has a sequential activity. Although the results presented refer to indoor/outdoor classification, the architecture is scalable in order to be used in much wider and detailed context classification. A community of service robots, contributing with their own contextual experience to dynamically improve the classification architecture, can use cloud-based technologies.
336594_1_En_21_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01343483 , version 1 (08-07-2016)
Paternité
Tiago Ferreira, Fábio Miranda, Pedro Sousa, José Barata, João Pimentão. Context Classifier for Service Robots. 6th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2015, Costa de Caparica, Portugal. pp.196-203, ⟨10.1007/978-3-319-16766-4_21⟩. ⟨hal-01343483⟩
33 Consultations
163 Téléchargements
