Experimental Wireless Wattmeter for Home Energy Management Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a novel prototype device for domestic load energy consumption monitoring. Zigbee-based wireless connectivity is included as a basic feature of the prototype. The proposed device allows individual tracking of major energy consumption loads. Real time energy data is acquired and transmitted through a RF link to a wireless terminal unit, which works as a data logger and as a human-machine interface. Both voltage and current measurements are implemented using Hall Effect principle based transducers, while C code is developed on two 16-bit RISC MCU. The experimental setup is described and tests are conducted in order to assess its performance.
336594_1_En_35_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01343500 , version 1 (08-07-2016)
Paternité
Eduardo G. Rodrigues, T. Caramelo, Tiago P. Mendes, Radu Godina, João S. Catalão. Experimental Wireless Wattmeter for Home Energy Management Systems. 6th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2015, Costa de Caparica, Portugal. pp.327-336, ⟨10.1007/978-3-319-16766-4_35⟩. ⟨hal-01343500⟩
69 Consultations
160 Téléchargements
