Building and promoting a linux-based operating system to support virtual organizations for next generation grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Construction d'un système d'exploitation fondé sur Linux pour le support des organisations virtuelles dans les grilles de nouvelle génération
This document comprises the final report on the IST Integrated Project XtreemOS - "Building and promoting a Linux-based operating systems to support virtual organizations for next generation Grids". The project started in June 2006 and ended in September 2010. The XtreemOS operating system provides for Grids what a traditional operating system offers for a single computer: abstraction from the hardware and secure resource sharing between different users. It thus simplifies the work of users belonging to virtual organizations by giving them the illusion of using a traditional computer while removing the burden of complex resource management issues of a typical Grid environment. We have developed a comprehensive set of cooperating system services. XtreemOS software components range from Linux kernel modules to application-support libraries. The XtreemOS operating system provides three major distributed services to users: application execution management (providing scalable resource discovery and job scheduling for distributed interactive applications), data management (accessing and storing data in XtreemFS, a POSIX-like file system spanning the Grid) and virtual organization management (building and operating dynamic virtual organizations). Three flavours of the system have been implemented for individual PC, clusters and mobile devices (PDA, smartphone, notebook). The XtreemOS software has been experimented and validated with a wide range of applications. Various demonstrators were implemented, shown at different events and published on the web. The project results are available as open source software. The consortium member organizations plan to exploit some of the results in follow-up research projects and in future products. 1/
XOS-finalpublishabelreport.pdf (1.51 Mo) Télécharger le fichier
hal-01346094 , version 1 (18-07-2016)
  • HAL Id : hal-01346094 , version 1
Christine Morin. Building and promoting a linux-based operating system to support virtual organizations for next generation grids. [Research Report] Inria Rennes Bretagne Atlantique. 2011, pp.29. ⟨hal-01346094⟩
477 Consultations
152 Téléchargements
