New interface
Journal articles
Inverse regression approach to robust nonlinear high-to-low dimensional mapping
Emeline Perthame 1 Florence Forbes 1, * Antoine Deleforge 2
* Corresponding author
1 MISTIS - Modelling and Inference of Complex and Structured Stochastic Systems
Inria Grenoble - Rhône-Alpes, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, LJK - Laboratoire Jean Kuntzmann
2 PANAMA - Parcimonie et Nouveaux Algorithmes pour le Signal et la Modélisation Audio
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : The goal of this paper is to address the issue of nonlinear regression with outliers, possibly in high dimension, without specifying the form of the link function and under a parametric approach. Nonlinearity is handled via an underlying mixture of affine regressions. Each regression is encoded in a joint multivariate Student distribution on the responses and covariates. This joint modeling allows the use of an inverse regression strategy to handle the high dimensionality of the data, while the heavy tail of the Student distribution limits the contamination by outlying data. The possibility to add a number of latent variables similar to factors to the model further reduces its sensitivity to noise or model misspecification. The mixture model setting has the advantage of providing a natural inference procedure using an EM algorithm. The tractability and flexibility of the algorithm are illustrated in simulations and real high-dimensional data with good performance that compares favorably with other existing methods.
Document type :
Journal articles
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-01347455
Contributor : Florence Forbes Connect in order to contact the contributor
Submitted on : Thursday, November 30, 2017 - 10:59:06 AM
Last modification on : Friday, August 5, 2022 - 2:54:52 PM
File
JMVA-17-48-EiC-REV3.pdf
Identifiers
Citation
Emeline Perthame, Florence Forbes, Antoine Deleforge. Inverse regression approach to robust nonlinear high-to-low dimensional mapping. Journal of Multivariate Analysis, 2018, 163, pp.1 - 14. ⟨10.1016/j.jmva.2017.09.009⟩. ⟨hal-01347455v2⟩
Share
Metrics
Record views
1298
Files downloads
991
