Abstract : Continuing research in [13] and [14] on well-posedness of the optimal time control problem with a constant convex dynamics in a Hilbert space we adapt one of the regularity conditions obtained there to a slightly more general problem, where nonaffine additive term appears. We prove existence and uniqueness of a minimizer in this problem as well as continuous differentiability of the value function, which can be seen as the viscosity solution to a Hamilton-Jacobi equation, near the boundary.
https://hal.inria.fr/hal-01347544 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, July 21, 2016 - 11:20:19 AM Last modification on : Thursday, July 21, 2016 - 11:48:12 AM
Vladimir Goncharov, Fátima Pereira. Geometric Conditions for Regularity of Viscosity Solution to the Simplest Hamilton-Jacobi Equation. 25th System Modeling and Optimization (CSMO), Sep 2011, Berlin, Germany. pp.245-254, ⟨10.1007/978-3-642-36062-6_25⟩. ⟨hal-01347544⟩
