Abstract : While active flow control is an established method for controlling flow separation on vehicles and airfoils, the design of the actuation is often done by trial and error. In this paper, the development of a discrete and a continuous adjoint flow solver for the optimal control of unsteady turbulent flows governed by the incompressible Reynolds-averaged Navier-Stokes equations is presented. Both approaches are applied to testcases featuring active flow control of the blowing and suction type and are compared in terms of accuracy of the computed gradient.
https://hal.inria.fr/hal-01347552 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, July 21, 2016 - 11:22:07 AM Last modification on : Monday, December 28, 2020 - 10:22:04 AM
Angelo Carnarius, Frank Thiele, Emre Özkaya, Anil Nemili, Nicolas R. Gauger. Optimal Control of Unsteady Flows Using a Discrete and a Continuous Adjoint Approach. 25th System Modeling and Optimization (CSMO), Sep 2011, Berlin, Germany. pp.318-327, ⟨10.1007/978-3-642-36062-6_32⟩. ⟨hal-01347552⟩
