Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : We present a weak formulation for a steady fluid-structure interaction problem using an embedding domain technique with penalization. Except of the penalizing term, the coefficients of the fluid problem are constant and independent of the deformation of the structure, which represents an advantage of this approach. A second advantage of this model is the fact that the continuity of the stress at the fluid-structure interface does not appear explicitly. Numerical results are presented.
https://hal.inria.fr/hal-01347557 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, July 21, 2016 - 11:22:59 AM Last modification on : Wednesday, March 14, 2018 - 4:51:18 PM
Cornel Marius Murea, Andrei Halanay. Embedding Domain Technique for a Fluid-Structure Interaction Problem. 25th System Modeling and Optimization (CSMO), Sep 2011, Berlin, Germany. pp.358-367, ⟨10.1007/978-3-642-36062-6_36⟩. ⟨hal-01347557⟩
