Research on the Inconsistency Checking in Agricultural Knowledge Base - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper will propose a method to check the knowledge inconsistency in the agricultural knowledge Base, which is one the main measures to evaluate the agricultural knowledge base. This paper will pay attention to analyzing main types of knowledge inconsistencies and factors arousing it, and then discuss possible solving strategies which reduce agricultural knowledge inconsistency, so that agricultural knowledge is utilized correctly. In our practical application, it is very effective to find the inconsistency.
978-3-642-36124-1_35_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01348110 , version 1 (22-07-2016)
Paternité
Nengfu Xie. Research on the Inconsistency Checking in Agricultural Knowledge Base. 6th Computer and Computing Technologies in Agriculture (CCTA), Oct 2012, Zhangjiajie, China. pp.290-296, ⟨10.1007/978-3-642-36124-1_35⟩. ⟨hal-01348110⟩
64 Consultations
58 Téléchargements
