Application of Quadratic Rotation-Orthogonal Composite Experimental Design to Assess the Relationship between Growth Environment and Ultraweak Luminescence of Osmanthus Tree Seedings - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
Yong Yu
  • Function : Author
Yao Zhan
  • Function : Author
Yi Lin
  • Function : Author
Jianping Li
  • Function : Author
  • PersonId : 986567
Quadratic rotation-orthogonal composite experimental design was applied in this experiment to analyze the ultraweak luminescence property of osmanthus tree seedings affected by multilateral growth environmental factors. The influence models of four factors on luminescence were established including illumination, temperature, humidity, and moisture. The ANOVA (analysis of variance) analysis showed that different factors and their interaction had different effect on luminescence property, among which the linear effects of four variables, the quadratic effects of illumination, relative humidity and moisture, and the interaction effect of illumination × moisture and temperature × relative humidity all have significant effect on the luminous value of osmanthus (p ≤ 0.01). The maximum luminous value was obtained when ten stick of lamp tube (intensity of illumination value 4229 Lx) was used, mean temperature, humidity and water were 35 ℃, 85% and 90 mL/d respectively. On the base of that, linear effects and interactions that affected ultraweak luminescence were further studied.
978-3-642-36137-1_15_Chapter.pdf (4 Ko) Télécharger le fichier
Origin Files produced by the author(s)
Dates and versions
hal-01348222 , version 1 (22-07-2016)
Identifiers
Cite
Yong Yu, Yao Zhan, Yi Lin, Chunfang Wang, Jianping Li. Application of Quadratic Rotation-Orthogonal Composite Experimental Design to Assess the Relationship between Growth Environment and Ultraweak Luminescence of Osmanthus Tree Seedings. 6th Computer and Computing Technologies in Agriculture (CCTA), Oct 2012, Zhangjiajie, China. pp.117-125, ⟨10.1007/978-3-642-36137-1_15⟩. ⟨hal-01348222⟩
61 View
44 Download
Share
Gmail Mastodon Facebook X LinkedIn More
