3D Imaging from Video and Planar Radiography
In this paper we consider dense volumetric modeling of moving samples such as body parts.
Most dense modeling methods consider samples observed with a moving X-ray device and cannot easily handle moving samples.
We propose a novel method that uses a surface motion capture system associated to a single low-cost/low-dose planar X-ray imaging device for dense in-depth attenuation information.
Our key contribution is to rely on Bayesian inference to solve for a dense attenuation volume given planar radioscopic images of a moving sample. The approach enables multiple sources of noise to be considered and takes advantage of limited prior information to solve an otherwise ill-posed problem.
Results show that the proposed strategy is able to reconstruct dense volumetric attenuation models from a very limited number of radiographic views over time on simulated and in-vivo data.
Imagerie médicale
2016_Pansiot_MICCAI_Xrays3d_HALv0.pdf (1.15 Mo)
Télécharger le fichier
pansiot16xrays3d_64 (1).png (4.14 Ko)
2016_Pansiot_MICCAI_Xrays3d.mp4 (1.86 Mo)
2016_Pansiot_MICCAI_Xrays3d_v2.mp4 (3.63 Mo)
Format : Figure, Image
Format : Vidéo
Format : Vidéo
Commentaire : Better encoded for android support.
