A Hybrid High-Order method for the steady incompressible Navier--Stokes problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
In this work we introduce and analyze a novel Hybrid High-Order method for the steady incompressible Navier--Stokes equations. The proposed method is inf-sup stable on general polyhedral meshes, supports arbitrary approximation orders, and is (relatively) inexpensive thanks to the possibility of statically condensing a subset of the unknowns at each nonlinear iteration. We show under general assumptions the existence of a discrete solution, which is also unique provided a data smallness condition is verified. Using a compactness argument, we prove convergence of the sequence of discrete solutions to minimal regularity exact solutions for general data. For more regular solutions, we prove optimal convergence rates for the energy-norm of the velocity and the $L^2$-norm of the pressure under a standard data smallness assumption. More precisely, when polynomials of degree $k\ge 0$ at mesh elements and faces are used, both quantities are proved to converge as $h^{k+1}$ (with $h$ denoting the meshsize).
nsho.pdf (487.32 Ko) Télécharger le fichier
hal-01349519 , version 1 (27-07-2016)
hal-01349519 , version 2 (13-01-2017)
Paternité
  • HAL Id : hal-01349519 , version 1
Daniele Di Pietro, Stella Krell. A Hybrid High-Order method for the steady incompressible Navier--Stokes problem. 2016. ⟨hal-01349519v1⟩
615 Consultations
316 Téléchargements
