Some results on sparse L2-L0 reconstruction: Continuous Exact L0 penalties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Laure Blanc-Féraud
Emmanuel Soubies
Gilles Aubert
  • Fonction : Auteur
  • PersonId : 947054
A smooth exact approximation of functional L2-L0 (least squares functional with sparse penalizing term using a L0 norm) is presented. This functional, named CEL0 for Continuous Exact L0 approximation is said exact as it preserves global minimizers and remove some of the local minimizers of the L2-L0 functional. More general results on smooth approximation of the L2-L0 functional are also given, describing a class of continuous functions with the properties of preservation of minimizers as described above. Simulation results are presented.
Présentation_NCMIP_2016.pdf (6.72 Mo) Télécharger le fichier
hal-01349670 , version 1 (29-07-2016)
  • HAL Id : hal-01349670 , version 1
Laure Blanc-Féraud, Emmanuel Soubies, Gilles Aubert. Some results on sparse L2-L0 reconstruction: Continuous Exact L0 penalties. NCMIP 2016 - New Computational Methods for Inverse Problem , ENS Cachan, Apr 2016, Cachan, France. ⟨hal-01349670⟩
217 Consultations
72 Téléchargements
