A new method for interoperability between lexical resources using MDA approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lexical resources are increasingly multiplatform due to the diverse needs of linguists. Merging, comparing, finding correspondences and deducing differences between these lexical resources remain difficult tasks. Thus, inte-roperability between these resources is hard even impossible to achieve. In this context, we establish a new method based on MDA approach to resolve interoperability between lexical resources. The proposed method consists of building common structure (OWL-DL ontology) for involved resources. This common structure has the ability to communicate involved resources. Hence, we may create a complex grid between involved resources allowing transformation from one format to another. We experiment our new built method on an LMF lexicon.
1570286710.pdf (229.92 Ko) Télécharger le fichier
hal-01350524 , version 1 (30-07-2016)
Paternité
  • HAL Id : hal-01350524 , version 1
Malek Lhioui, Kais Haddar, Laurent Romary. A new method for interoperability between lexical resources using MDA approach. AISI 2016 The 2nd International Conference on Advanced Intelligent Systems and Informatics, Oct 2016, Cairo, Egypt. ⟨hal-01350524⟩
422 Consultations
185 Téléchargements
