Neural Fitted Actor-Critic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matthieu Zimmer
Yann Boniface
  • Fonction : Auteur
  • PersonId : 778629
  • IdRef : 140410805
Alain Dutech
A novel reinforcement learning algorithm that deals with both continuous state and action spaces is proposed. Domain knowledge requirements are kept minimal by using non-linear estimators and since the algorithm does not need prior trajectories or known goal states. The new actor-critic algorithm is on-policy, offline and model-free. It considers discrete time, stationary policies, and maximizes the discounted sum of rewards. Experimental results on two common environments, showing the good performance of the proposed algorithm, are presented.
main.pdf (410.48 Ko) Télécharger le fichier
hal-01350651 , version 1 (23-08-2016)
  • HAL Id : hal-01350651 , version 1
Matthieu Zimmer, Yann Boniface, Alain Dutech. Neural Fitted Actor-Critic. ESANN 2016 - Symposium on Artificial Neural Networks, Computational Intelligence and Machine Learning, Apr 2016, Bruges, Belgium. ⟨hal-01350651⟩
331 Consultations
330 Téléchargements
