Consistency in 3D
Comparisons of different consistency models often try to place them in a linear strong-to-weak order. However this view is clearly inadequate, since it is well known, for instance, that Snapshot Isolation and Serialisability are incomparable. In the interest of a better understanding, we propose a new classification, along three dimensions, related to: a total order of writes, a causal order of reads, and transactional composition of multiple operations. A model may be stronger than another on one dimension and weaker on another. We believe that this new classification scheme is both scientifically sound and has good explicative value. The current paper presents the three-dimensional design space intuitively.
