Goal Oriented Value Object Classification for Healthcare Service Development - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gilmini Dantanarayana
  • Fonction : Auteur
  • PersonId : 987147
Chathurika Wickramage
  • Fonction : Auteur
  • PersonId : 987148
Prasad Jayaweera
  • Fonction : Auteur
  • PersonId : 987149
In present day, performance of inter and intra cooperative enterprise systems can be guaranteed by provisioning e-Services. Modeling values for e-Service is challenging due to inherited complexity of service constellations. In this research, we present a classification to guide identification of different types of value objects that could be considered as mostly relevant and appropriate in healthcare trading scenarios. Further we propose a set of guidelines that direct construction of e3-Value model along with the instructions to figure out the value objects. The classification and the guidelines are capable enough to provide clear and precise understanding of goal aligned e-Services to be developed and deployed by e-Service designers. Thus the proposed approach also facilitates business/IT alignment by realizing business motivations and top level goals in e3-Value model which directly assist in defining business system requirements.
978-3-642-55355-4_14_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01350918 , version 1 (02-08-2016)
Paternité
Gilmini Dantanarayana, Chathurika Wickramage, Prasad Jayaweera. Goal Oriented Value Object Classification for Healthcare Service Development. 15th International Conference on Informatics and Semiotics in Organisations (ICISO), May 2014, Shanghai, China. pp.135-144, ⟨10.1007/978-3-642-55355-4_14⟩. ⟨hal-01350918⟩
42 Consultations
87 Téléchargements
