Hierarchical Clustering Based Web Service Discovery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Huiying Gao
  • Fonction : Auteur
  • PersonId : 987141
Susu Wang
  • Fonction : Auteur
  • PersonId : 987177
Lily Sun
  • Fonction : Auteur
  • PersonId : 982987
Fuxing Nian
  • Fonction : Auteur
  • PersonId : 987178
This paper presents a hierarchical clustering method for semantic Web service discovery. This method aims to improve the accuracy and efficiency of the traditional service discovery using vector space model. The Web service is converted into a standard vector format through the Web service description document. With the help of WordNet, a semantic analysis is conducted to reduce the dimension of the term vector and to make semantic expansion to meet the user’s service request. The process and algorithm of hierarchical clustering based semantic Web service discovery is discussed. Validation is carried out on the dataset.
978-3-642-55355-4_29_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01350934 , version 1 (02-08-2016)
Paternité
Huiying Gao, Susu Wang, Lily Sun, Fuxing Nian. Hierarchical Clustering Based Web Service Discovery. 15th International Conference on Informatics and Semiotics in Organisations (ICISO), May 2014, Shanghai, China. pp.281-291, ⟨10.1007/978-3-642-55355-4_29⟩. ⟨hal-01350934⟩
67 Consultations
184 Téléchargements
