A Multi-attribute Collaborative Filtering Recommendation Algorithm Based on Improved Group Decision-Making - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Changrui Yu
  • Fonction : Auteur
  • PersonId : 987185
Yan Luo
  • Fonction : Auteur
  • PersonId : 987186
The paper builds an evaluation model of user interest based on resource multi-attributes, proposes a modified Pearson-Compatibility multi-attribute group decision-making algorithm, and introduces the algorithm to solve the recommendation problem of k-neighbor similar users. Considering the characteristics of collaborative filtering recommendation, the paper addresses the issues on the preference differences of similar users, incomplete values, and advanced converge of the algorithm. Thus the paper realizes multi-attribute collaborative filtering. Finally, the effectiveness of the algorithm is proved by an experiment of collaborative recommendation among multi-users based on virtual environment.
978-3-642-55355-4_33_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01350939 , version 1 (02-08-2016)
Paternité
Changrui Yu, Yan Luo, Kecheng Liu. A Multi-attribute Collaborative Filtering Recommendation Algorithm Based on Improved Group Decision-Making. 15th International Conference on Informatics and Semiotics in Organisations (ICISO), May 2014, Shanghai, China. pp.320-330, ⟨10.1007/978-3-642-55355-4_33⟩. ⟨hal-01350939⟩
70 Consultations
188 Téléchargements
