The Construction of a Clinical Decision Support System Based on Knowledge Base - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Based on a review of domestic and foreign research, application status, classification, composition, and the main problem of a clinical decision support system, this paper proposed a CDSS mode based on a knowledge base. On KB-CDSS mode, this paper discussed the architecture, principle, process, construction of the knowledge base, system design, and application value, then introduced the application WanFang Data Clinical Diagnosis and Treatment Knowledge Base.
978-3-642-55355-4_40_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01350947 , version 1 (02-08-2016)
Paternité
Jianwu Xu, Xiumei Zhang, Yuhua Cheng, Gongliang Yang, Junli Liu. The Construction of a Clinical Decision Support System Based on Knowledge Base. 15th International Conference on Informatics and Semiotics in Organisations (ICISO), May 2014, Shanghai, China. pp.388-397, ⟨10.1007/978-3-642-55355-4_40⟩. ⟨hal-01350947⟩
209 Consultations
388 Téléchargements
