Research into Inventory Optimization of a Two-Echelon Distribution System Based on Particle Swarm Optimization (PSO) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Based on the assumption that distributor and retailers adopt different replenishment policies, this article gives consideration to the relationship between the inventory strategies of the two echelon. The authors construct an inventory model of a two-echelon distribution system under stochastic demand, and solve the problem based on algorithm of Particle Swarm Optimization (PSO) to quantitatively get the optimal ordering strategies of distribution center and retailers.
978-3-642-55355-4_45_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01350953 , version 1 (02-08-2016)
Paternité
Jingti Han, Mingliang Yu, Lin Liu. Research into Inventory Optimization of a Two-Echelon Distribution System Based on Particle Swarm Optimization (PSO). 15th International Conference on Informatics and Semiotics in Organisations (ICISO), May 2014, Shanghai, China. pp.430-438, ⟨10.1007/978-3-642-55355-4_45⟩. ⟨hal-01350953⟩
75 Consultations
57 Téléchargements
