Tight and rigorous error bounds for basic building blocks of double-word arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Mathematical Software Année : 2017
We analyze several classical basic building blocks of double-word arithmetic (frequently called " double-double arithmetic " in the literature): the addition of a double-word number and a floating-point number, the addition of two double-word numbers, the multiplication of a double-word number by a floating-point number, the multiplication of two double-word numbers, the division of a double-word number by a floating-point number , and the division of two double-word numbers. For multiplication and division we get better relative error bounds than the ones previously published. For addition of two double-word numbers, we show that the previously published bound was wrong, and we provide a relative error bound. We introduce new algorithms for division. We also give examples that illustrate the tightness of our bounds.
a15res-joldes.pdf (382.82 Ko) Télécharger le fichier
hal-01351529 , version 1 (03-08-2016)
hal-01351529 , version 2 (29-03-2017)
hal-01351529 , version 3 (18-10-2017)
Mioara Maria Joldes, Jean-Michel Muller, Valentina Popescu. Tight and rigorous error bounds for basic building blocks of double-word arithmetic. ACM Transactions on Mathematical Software, 2017, 44 (2), pp.1 - 27. ⟨10.1145/3121432⟩. ⟨hal-01351529v3⟩
1207 Consultations
4038 Téléchargements
