Implementation of Business Process Reengineering Based on Workflow Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Wen Yang
  • Fonction : Auteur
  • PersonId : 987302
To achieve better performance of BPR, workflow management is integrated with BPR based on the core idea and steps of BPR. Main problems of hotel business process are studied, at the same the characteristics and advantages of WFM are introduced, which show that WFM is sound. Then BPR case of a five-star hotel in Guangzhou which adopts the WFM workflow is proposed. The rent and service charge processes are analyzed; the collaborative workflow and its new process after reengineering are also given, which achieve better results.
978-3-642-27281-3_5_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01351787 , version 1 (04-08-2016)
Paternité
Wen Yang, Hongjiang Chen. Implementation of Business Process Reengineering Based on Workflow Management. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.35-40, ⟨10.1007/978-3-642-27281-3_5⟩. ⟨hal-01351787⟩
146 Consultations
1161 Téléchargements
