The Design of Greenhouse Environment Control System Based on Variable Universe Fuzzy Control Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Haiyan He
  • Fonction : Auteur
  • PersonId : 987310
Heru Xue
  • Fonction : Auteur
  • PersonId : 987311
Greenhouse environment has the characteristics such as multiple-input, multiple-output, nonlinearity, and difficulties of establishing its accurate mathematical model. Therefore, in order to make the greenhouse environment control more effective and accurate, an expert system of variable universe fuzzy control based on BP neural network has been proposed. In this method an appropriate universe is selected according to the error and the changing rate of error to overcome the effect for greenhouse control when the error is too large or too small. The paper introduces the design of greenhouse environment control system based on variable universe fuzzy control in details, and presents the main control parameters.
978-3-642-27281-3_10_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01351794 , version 1 (04-08-2016)
Paternité
Haiyan He, Heru Xue. The Design of Greenhouse Environment Control System Based on Variable Universe Fuzzy Control Algorithm. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.72-78, ⟨10.1007/978-3-642-27281-3_10⟩. ⟨hal-01351794⟩
44 Consultations
71 Téléchargements
