Cooling Wet-Pad Fan Control System of Piggery Based on Zigbee - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In view of the traditional faults of wire network that complex wiring and costly wired network, a set of Zigbee wireless network technology based on the temperature and humidity data acquisition and control system is designed in this paper to improve the environmental temperature control in piggery. The Zigbee system which can monitor the real-time information of temperature and humidity in piggery and provide a convenient data supports for the further temperature control synthesizes the advantages of wireless networking and self healing.
978-3-642-27281-3_19_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01351804 , version 1 (04-08-2016)
Paternité
Runtao Wang, Fang Yang, Ming Li, Lei Tian, Yu Zhang. Cooling Wet-Pad Fan Control System of Piggery Based on Zigbee. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.147-154, ⟨10.1007/978-3-642-27281-3_19⟩. ⟨hal-01351804⟩
48 Consultations
144 Téléchargements
