The irregularity of two types of trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2016
The irregularity of a graph $G$ is defined as the sum of weights $|d(u)-d(v)|$ of all edges $uv$ of $G$, where $d(u)$ and $d(v)$ are the degrees of the vertices $u$ and $v$ in $G$, respectively. In this paper, some structural properties on trees with maximum (or minimum) irregularity among trees with given degree sequence and trees with given branching number are explored, respectively. Moreover, the corresponding trees with maximum (or minimum) irregularity are also found, respectively.
2807-9939-1-PB.pdf (368.23 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01352840 , version 1 (16-08-2016)
Li Jianxi, Yang Liu, Wai Shiu. The irregularity of two types of trees. Discrete Mathematics and Theoretical Computer Science, 2016, Vol. 17 no. 3 (3), pp.203-216. ⟨10.46298/dmtcs.2146⟩. ⟨hal-01352840⟩
Collections
TDS-MACS
60 Consultations
798 Téléchargements
